Labeling in ArcMap - Get Low Weighted Labels Not to Draw If Overlap?
2698
11-21-2011 03:31 PM
deleted-user-GpZRmORkzrlh
I would like to place weights on layers labels and have the lower weighted labels just not draw in ArcMap instead of drawing the overlapping label where it fits best on the map.  I want the label with highest weight to be drawn in a fixed location on the map, and then overlapping labels not be drawn at all instead of just moved to the side. Is there a way to do this easily?
MaraKaminowitz
There's a few things you can do thought they may not have perfect or consistent results without resorting to annotation or a labeling extension.
Play with the buffer option in your higher ranked labels. I usually need to set it to at least 3 to see results. It will keep other labels near that layer from displaying. You'll need to play around with it to make sure it doesn't block too many other labels.
In the label placement options, display your low weight label over a point if you are able to, and then make the point invisible. This will make it more likely to disappear and less likely to move.
Make sure "Allow overlapping labels" is not checked in any of your label properties.
