Is it possible to customize the login page in portal for arcgis.
25954
39
08-22-2017 11:01 AM
akshayloya
I've portal for Arcgis 10.5 (behind the firewall). I have to customize the login page with the client's company logo, banner and all those. How can I do this. Any work around ?
LindsayMaier
That's kind of what I figured. Thanks for the help - really appreciate it!
EricPeña
I'd appreciate the vote up...
https://community.esri.com/ideas/18029
Thanks.
LindsayMaier
Done!
MNIT-Kitty-Hurley
Thanks for submitting this idea, just upvoted. This is a huge issue in our organization's Portal (10.7) administration, so hope this is addressed soon!
AbeCoughlin
Thanks Eric! Very nice, simple work-around! I'm implementing in my new install.
FYI, there is a div that has a custom-logo class..., so maybe there is a way?
{{#info.signinThumbnail}}\n
<div class="custom-logo">\n
  <img src="{{info.hostname}}{{info.contextPath}}/rest/oauth2/orgInfo/{{info.signinThumbnail}}" alt="" />\n
</div>\n
{{/info.signinThumbnail}}
ChristinaCurry
Did you have any luck? I'm still hunting for the correct div 🙂
AbeCoughlin
Christina,
This is what I achieved...
To get this look, try this:
  • Find the <div> with class = "content-wrap" in oauth2.js (copy file and keep original safe).
  • Replace it with the code below (If you ignore the svg path, it's fairly simple).
  • Modify the text, id and logo for your organization.
  • Done.
Note that this does not change any functionality, just layout.
[ I'm quite sure that this is the only change I implemented at the time - if for some reason this does not work as intended, simply replace the original file and it will fix itself. I would appreciate feedback if it doesn't work and I'll explore if I made any other change and advise. ]
<div class="content-wrap">
    <div class="js-header header-bar flex flex-justify">
        <div class="font-size-1 page-title width-full"> <!-- Add own text/instruction/logo -->
            <span class="js-orgname"><b>City of Escondido</b></span>
            <small><br>Sign in with Windows credentials as below:<br>Username: <b>user@ecity</b><br>Password: <b>password</b></small>
            <span class="js-orgname"><img src="https://gisp.escondido.org/img/CityofChoiceBlue.png" style="float:right;" alt="Escondido City of Choice blue logo"></span><br>
        </div>
    </div>
    <div id="loginComponents">
        <div tabindex="0" class="alert alert-red js-message" id="errMessage"></div>
        <section class="arcgis-login">
            <div class=" accordion">
                <div class="js-flat-section flat-section is-active">
                    <div class="flat-title font-size--1 trailer-quarter" id="loginTitle" aria-expanded="true" role="heading" aria-level="4">
                        <span>Staff GIS Portal</span> <!-- Modify title -->
                    </div>
                    <div class="flat-content" role="region" aria-labelledby="loginTitle" id="loginPanel">
                        <form class="container" id="oauth" name="f" method="POST" action="https://gisp.escondido.org/portal/sharing/oauth2/signin" novalidate="" autocomplete="off">
                            <input type="hidden" id="oauth_state" name="oauth_state" value="XXX"> <!-- replace with value from your existing oauth2.js file -->
                            <input type="hidden" id="authorize" name="authorize" value="true">
                            <label class="field-icon">
                                <svg class="svg-icon" xmlns="http://www.w3.org/2000/svg" viewBox="0 0 16 16" focusable="false">
                                    <path d="M11 3a3 3 0 1 0-3 3 3 3 0 0 0 3-3zM8 5a2 2 0 1 1 2-2 2 2 0 0 1-2 2zm3 1H5a2 2 0 0 0-2 2v6a1 1 0 0 0 1 1h1a1 1 0 0 0 1 1h4a1 1 0 0 0 1-1h1a1 1 0 0 0 1-1V8a2 2 0 0 0-2-2zm1 3v5h-1V9h-1v6H6V9H5v5H4V8a1 1 0 0 1 1-1h6a1 1 0 0 1 1 1z"></path>
                                </svg>
                                <input type="text" name="username" id="user_username" placeholder="Username" aria-label="Username" class="padding-left-2" autocomplete="off" autocorrect="off" autocapitalize="none" spellcheck="false" required="">
                                <div class="input-error-message js-username-error"></div>
                            </label>
                                    <path d="M13 7V5A5 5 0 0 0 3 5v2a1.003 1.003 0 0 0-1 1v7a1.003 1.003 0 0 0 1 1h10a1.003 1.003 0 0 0 1-1V8a1.003 1.003 0 0 0-1-1zM4 5a4 4 0 0 1 8 0v2h-1V5a3 3 0 0 0-6 0v2H4zm6 2H6V5a2 2 0 0 1 4 0zm3 8H3V8h10zm-5-1H7V9h1v1h1v1H8v1h1v1H8z"></path>
                                </svg>
                                <input required="" type="password" name="password" id="user_password" placeholder="Password" aria-label="Password" class="padding-left-2">
                                <div class="input-error-message js-password-error"></div>
                            </label>
                            <label id="persistUserLabel" class=""><input type="checkbox" name="persist" id="persistUser">Keep me signed in</label>
                            <div class="flex">
                                <button id="signIn" type="submit" class="btn btn-small btn-fill margin-right-half">Sign In</button>
                                <button id="cancel" type="button" class="btn btn-small btn-fill btn-clear margin-left-half hide">Cancel</button>
                            </div>
                        </form>
                        <div class="leader-quarter btn-fill font-size--3"> <!-- Move ESRI logo [must keep ESRI for licensing purposes, probably] -->
                            <svg id="gnav-dist-esri-Australia-tm" xmlns="http://www.w3.org/2000/svg" width="84" height="30" viewBox="0 0 84 30" focusable="false"><title>Esri</title><g><path d="M77.377.695a2.51615,2.51615,0,0,0-2.5536,2.4884,2.58969,2.58969,0,0,0,5.1756,0A2.512,2.512,0,0,0,77.377.695ZM75.4635,24.12065h3.892V8.5485h-3.892ZM40.615,8.1597c-4.7019,0-8.4646,3.2749-8.4646,8.1744,0,4.89828,3.7627,8.17661,8.4646,8.17661a8.08656,8.08656,0,0,0,5.8516-2.31047L44.0102,19.7439a4.96654,4.96654,0,0,1-3.781,1.65148,4.03745,4.03745,0,0,1-4.1869-3.69818H47.9167V16.6269C47.9167,11.2076,44.9662,8.1597,40.615,8.1597Zm-4.5727,6.6168a3.87339,3.87339,0,0,1,4.023-3.6991c2.4334,0,3.9261,1.4292,3.9603,3.6991Zm17.3044-1.8482c0-1.1689,1.2333-1.655,2.2729-1.655a3.53132,3.53132,0,0,1,3.0376,1.5764l2.476-2.4735a6.83011,6.83011,0,0,0-5.418-2.2165c-3.1469,0-6.2621,1.5555-6.2621,5.0284,0,5.9379,8.4026,3.4059,8.4026,6.6172,0,1.23253-1.4594,1.78384-2.5946,1.78384a4.75239,4.75239,0,0,1-3.6905-1.905l-2.5144,2.5136a7.64753,7.64753,0,0,0,5.9779,2.313c3.1784,0,6.717-1.29823,6.717-4.99731C61.7511,13.4459,53.3467,15.7175,53.3467,12.9283Zm14.151-1.9166h-.0623V8.5485H63.5426V24.12065h3.8928V15.7815a3.91438,3.91438,0,0,1,4.1848-3.9252,7.452,7.452,0,0,1,1.7181.253l.1519-3.7259a5.03109,5.03109,0,0,0-1.3826-.2237A4.96277,4.96277,0,0,0,67.4977,11.0117ZM14.782,2.9606a10.41336,10.41336,0,0,0-2.651.2599.49091.49091,0,0,0-.6431.4729.65358.65358,0,0,0,.2394.5615,20.045,20.045,0,0,1,2.4735,2.1423c-.4694.0517-.9807.1379-1.5039.2462-.5847-1.264-2.4653-.1147-3.71354-.0648-.14639.006-.28684.0252-.43149.035A20.32772,20.32772,0,0,1,8.3415,3.6934a17.20722,17.20722,0,0,1,6.875-1.6255l.3721-.0098c.3124-.0027.3371-.2514.0435-.2915A13.53793,13.53793,0,0,0,8.35348,2.9124,14.41291,14.41291,0,0,0,.89854,10.791c-.44337,1.2475-2.21826,7.1947.935,12.29948a13.20182,13.20182,0,0,0,9.88737,6.6769,14.15347,14.15347,0,0,0,8.7522-1.05577c5.9511-2.64154,10.4956-12.55841,5.9499-19.747C24.6289,5.6461,19.9278,2.7361,14.782,2.9606ZM12.5233,7.6083a17.75423,17.75423,0,0,1,2.3616-.3686,15.74087,15.74087,0,0,1,1.7479,2.5404c-.8053.3896-1.8781.6879-2.3146,1.3123a1.78056,1.78056,0,0,0-.2318.9943,23.589,23.589,0,0,0-3.8774,1.2862c-.45286-1.3319-.85009-2.659-1.12365-3.8421C10.3814,8.2941,11.8985,8.0927,12.5233,7.6083Zm6.6103,15.87993c-.3546.03749-.7071.08277-1.0169.13057a14.62456,14.62456,0,0,0-2.6843.72209,43.94209,43.94209,0,0,1-2.6676-4.43649A15.48586,15.48586,0,0,1,18.54,18.4602a4.61747,4.61747,0,0,0,.6909.9559C19.9871,20.1902,18.7892,21.299,19.1336,23.48823ZM10.5303,14.3485a19.29324,19.29324,0,0,1,3.5604-1.2862,2.03511,2.03511,0,0,1-.1827.903,2.50151,2.50151,0,0,0,.1336,1.7748c.7549,1.0985,2.0083.4882,2.9518.8834a2.15739,2.15739,0,0,1,.9633.8389,16.049,16.049,0,0,0-5.7053,1.4109A41.82526,41.82526,0,0,1,10.5303,14.3485Zm.8321,4.9371c-.0699.0333-.145.0742-.2171.1101-1.1019-.3073-1.78517-.478-3.25617-.7801a3.08944,3.08944,0,0,0-2.15123.1758c-.15959.0461-.3128.0879-.46173.1323-.14893-.3815-.29663-.7768-.44556-1.2018a27.12084,27.12084,0,0,1,4.82187-2.9851C10.1514,16.2283,10.8665,18.2204,11.3624,19.2856Zm.7674,4.52863a9.48665,9.48665,0,0,0,.6047-1.88965c.5692.95763,1.2487,1.9989,1.7744,2.814A17.3346,17.3346,0,0,0,11.837,26.4243,11.23781,11.23781,0,0,1,12.1298,23.81423ZM17.4642,9.1779c-.0102.0145-.0282.0261-.0393.0401a23.04534,23.04534,0,0,0-1.3771-2.1111,21.90906,21.90906,0,0,1,3.3743.1084C18.4082,7.5781,17.9609,8.4687,17.4642,9.1779Zm-9.028,1.0938c.01836-.0256.03837-.0465.05716-.0717.23344,1.1821.51294,2.1606.88552,3.5178a33.49783,33.49783,0,0,0-4.976,2.9723,17.18753,17.18753,0,0,1-.5889-1.9465,1.77168,1.77168,0,0,1,1.47617-1.325C6.51758,13.2957,7.57083,11.4696,8.43624,10.2717ZM3.0267,8.4883A15.96075,15.96075,0,0,1,7.74876,3.9686a26.225,26.225,0,0,0,.21806,2.6928q-.85463.0852-1.69211.2109a12.08231,12.08231,0,0,0-3.11438,4.0878A14.926,14.926,0,0,1,3.0267,8.4883ZM2.16984,9.9256s.06188,1.0601.1131,1.8329a11.90283,11.90283,0,0,0-1.17919,1.5914A9.53467,9.53467,0,0,1,2.16984,9.9256Zm7.664,18.35671A12.62638,12.62638,0,0,1,1.72131,20.029a17.47511,17.47511,0,0,1-.65164-6.473.65293.65293,0,0,0,.38018.0167c.13486-.0922.61581-.4302.95763-.7277.00472.0393.01241.0892.01792.1314a12.04271,12.04271,0,0,0-.40064,2.7099,19.25881,19.25881,0,0,1,1.28616,1.7062c-.31061.2304-.9051.6418-1.04468.7417a.62859.62859,0,0,0-.114,1.0148.56565.56565,0,0,0,.6124-.0103,10.69141,10.69141,0,0,1,1.06609-.769c.151.3926.29182.7468.43052,1.0848a1.34447,1.34447,0,0,0-.34269.79893,2.46079,2.46079,0,0,0,1.91875,2.35994c.035.01022.06057.01363.09388.02307.0499.07508.09517.14674.14761.22357A5.74221,5.74221,0,0,0,5.03032,23.9226c-.13189.17244-.28125.43018-.15959.48139a2.1227,2.1227,0,0,0,.71824-.03408c.46644-.08967.82618-.606,1.14833-.7955a17.99721,17.99721,0,0,0,1.67159,1.87942c.02866.11947.05506.24576.08792.3516a7.47254,7.47254,0,0,0,.495,1.19578A12.16213,12.16213,0,0,0,10.456,27.562,8.34474,8.34474,0,0,0,9.83383,28.28231Zm.98917.31236a4.36881,4.36881,0,0,1,.5054-.6256c.4672.30983.9682.66493,1.3677.89366A9.59947,9.59947,0,0,1,10.823,28.59467Zm3.1128.30983a22.07987,22.07987,0,0,1-2.0088-1.47057,14.04631,14.04631,0,0,1,3.1281-1.88878c.4016.63076,1.7267,2.50678,2.2575,3.11184A17.30216,17.30216,0,0,1,13.9358,28.9045Zm6.7055-1.50806a16.58869,16.58869,0,0,1-2.2045.98742,23.42994,23.42994,0,0,1-2.4402-3.20141,13.9527,13.9527,0,0,1,3.3466-.82111,7.49493,7.49493,0,0,0,.4438,1.09423,2.51925,2.51925,0,0,0,.6486.85345c.0853-.05287.1644-.11519.2484-.16981C20.678,26.55828,20.6665,26.98505,20.6413,27.39644ZM20.3106,5.9188c-.2702-.1719-.6068-.1079-.4669.1933a4.06966,4.06966,0,0,0,.4272.5122,19.53821,19.53821,0,0,0-4.856-.3645,15.62334,15.62334,0,0,0-2.8614-2.7649c4.999-.3111,9.4897,1.7565,11.4737,4.1856a15.42616,15.42616,0,0,0-2.6677-.9628A5.95374,5.95374,0,0,0,20.3106,5.9188Zm1.0946,21.06538c.023-.40711.0402-.92267.0529-1.39637a12.11693,12.11693,0,0,0,1.3695-1.23757,12.42379,12.42379,0,0,1,1.4275.23895A11.02525,11.02525,0,0,1,21.4052,26.98418Zm3.8245-3.72467a4.1318,4.1318,0,0,1-.6328.89444,9.77165,9.77165,0,0,0-1.2722-.37468c.0786-.09387.1635-.18267.2395-.27915.2688-1.7957-.3376-2.371.4211-4.01392.053-.1144.111-.2407.1716-.3713a11.3497,11.3497,0,0,1,1.1526.3858A30.26049,30.26049,0,0,1,25.2297,23.25951Zm-.7079-4.91621c.1959-.4072.4118-.8399.6456-1.2708.0607.5479.1042,1.0813.1307,1.5635C25.0578,18.5302,24.7936,18.4346,24.5218,18.3433Zm2.2178,1.1257-.1937.75629a18.08656,18.08656,0,0,1-.8318,2.22245,25.61647,25.61647,0,0,0,.1481-2.72944.59489.59489,0,0,0,.5586-.3414c.0568-.1946-.5637-.495-.5637-.495a20.74328,20.74328,0,0,0-.1725-2.7001c.1426-.2292.2869-.452.4341-.6551a12.095,12.095,0,0,0-.1852-1.5743,1.21486,1.21486,0,0,0,.323.0747c.2825.0043.2817-.1899.1912-.2978a3.78494,3.78494,0,0,0-.6423-.4195,12.02044,12.02044,0,0,0-2.7811-5.3203,14.9875,14.9875,0,0,1,1.7548.7732,9.39245,9.39245,0,0,1,2.2114,4.9204A12.16755,12.16755,0,0,1,26.7396,19.469Z"></path><path d="M80.9857,8.7917V8.5528h1.2188v.2389H81.736V9.9832h-.2835V8.7917Zm1.87-.2389L83.221,9.577l.3679-1.0242h.4062V9.9832h-.262V8.8293l-.396,1.1539h-.2287l-.3995-1.1539V9.9832h-.262V8.5528Z"></path></g></svg>
                        </div>
                    </div>
                </div>
            </div>
        </section>
    </div>
</div>
Tags (3)
ChristinaCurry
Oh great! Attempt 1 did not work out (sign-in page was just blank) but it's very possible I made a mistake. I will give it another go sometime this week and let you know!
RuchiraWelikala2
Thank you for this. It works for the most part but when ever I remove one of the dynamic keys from the existing code, it errors out.
For instance, I tried removing this:  {{^info.orgName}}\n and it just errors out. Wondering if there's a way around it.
AbeCoughlin
I presume that it needs 'org.Name' to relate it with the organization that you are signing in under. As I didn't change that, nor have a need to, I don't have an answer for you.
My only thought would be that:
  • if you want the login to work for any organization, then you have to allow the user to input the organization - as it is now.
  • if you want the login to work for one organization only, then you could hard-code this value into the code.
