Group layers in portal for arcgis
8881
10
07-19-2016 02:32 AM
AliBarakat
Hello,
is there any way to group layers in portal for arcgis?
in web map or web appbuilder?
Thanks
DerekLaw
Esri Esteemed Contributor
Hi Ali,
This is currently not possible in the Portal map viewer - but the enhancement is being considered for a future release of both ArcGIS Online and Portal for ArcGIS.
Please vote for the enhancement on the ArcGIS Ideas site here: https://community.esri.com/ideas/12073
Hope this helps,
JayantaPoddar
It might not be exactly what you wanted, but a similar functionality is available with June 2016 update of WAB.
http://doc.arcgis.com/en/web-appbuilder/
The new Group Filter Widget allows you to create groupings of layers to apply a value filter to. You have the option of saving and reloading your defined groupings so you can come back anytime and resume your work.
Think Location
RebeccaStrauch__GISP
...but I don't think the June 2016 updates to ArcGIS Online WAB are available yet for WAB developer edition (we should see any day, I hope) or Portal (which usually comes after the developer edition release.
update on developer editin v2.1....just released
Web AppBuilder for ArcGIS v2.1 Developer Edition Now Available! | ArcGIS Blog
Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
EDIT:
see Web AppBuilder Developer Edition - Customization Resource List​  for additional news when other widgets are released or updated, etc.
DerekLaw
Hi Ali,
Hope this helps,
Derek, that idea is marked as a duplicate and refers users to https://community.esri.com/ideas/9987   and mentions it is already "under consideration" but that doesn't mean people shouldn't get out and vote.
RoseZhou2
@DerekLaw
Is this feature available in Portal for ArcGIS 10.8.1?
Thanks
Rose
DerekLaw
Hi @RoseZhou2,
I believe you're asking if group layers are available in an enterprise portal at 10.8.1. The answer is "no". Group layer capability was added to AGOL in July 2020, and ArcGIS Enterprise 10.8.1 was released in July 2020 - typically, functionality introduced in AGOL is added to Enterprise later on.
Hope this helps,
RoseZhou2
Thanks @DerekLaw ,
Is the group layers are available in an enterprise portal at 10.9.1? This feature is essential to one of our project.
Thanks
Rose
DerekLaw
Hi @RoseZhou2,
I checked with the ArcGIS Enterprise Dev team and unfortunately, this capability is not yet available in an enterprise portal. Not even at the 10.9.1 release. Sorry.
Hope this helps,
West_SacramentoCalifornia
Hello, what am I missing here?  I created a group in my web map (portal enterprise) and it shows fine.  However, I save the map and it does not show in the web mapping application.
