Federating ArcGIS server
3318
03-25-2016 09:00 PM
JosephPack1
anybody else experience this issue, I did the following
  • Updated 10.3 to 10.4
    • server
    • portal
    • web adaptor
but when I attempt to federate I get this issue.
JosephPack1
Solved it.
managed to do it using the mydomain.com/7443/arcgis/portaladmin
JayantaPoddar
Joseph,
Have you deleted the older version of ArcGIS Web Adaptor, and installed the new version of web adaptor with the same name?
Also let me know if the previous version of Server was federated with Portal. If yes, it is not recommended to un-federate the Server before upgrade.
Think Location
JosephPack1
Yes I have deleted the older version (10.3).
Yes the previous version of Server was federated with Portal.
JosephPack1
Solved it.
