Feature Layer that references a database table is visible to users only if they are administrators
1295
11-20-2024 05:07 AM
PanGIS
Hello!
ArcGIS Enterprise 11.3
Feature Layer that reference a database table is visible to users only if they are administrators
The service is shared in groups and also with the org, but irrespective to this, only if I make them admin they can see a dashboard containing this data. Everything is fine with hosted FL.
It looks like that it has to do with permission of the database table itself, but I am not sure what I need to change exactly.
I published the service and I register the database. The database isn't geo enabled.
Thanks!
JakeSkinner
Esri Esteemed Contributor
Hi @PanGIS, are you also sharing the Map Image Layer to the Org and Groups?
JakeSkinner
PanGIS
Hi @JakeSkinner, this seemed to be the issue, completely forgot about it.
Thanks!
