Error: The Layer, ######, cannot be added to the map
30690
16
09-07-2017 09:13 AM
EricShreve
I recently upgraded our ArcGIS Server 10.1 to ArcGIS Enterprise 10.5.1 and have begun to publish map/feature services through ArcMap 10.5.1. I am able to successfully publish content to our ArcGIS Server from ArcMap and add content/data in ArcGIS Online.
I am beginning the process of migrating from ArcGIS Online to Portal and want to publish content from ArcGIS Pro to Portal for ArcGIS. While in ArcGIS Pro, I attempt to share my data as a web layer and run the geoprocessing task and I am prompted with success that the data has published as a map service. When I access my Portal I attempt to visualize the data by adding it to a new map and am promoted with this error message "Error: The Layer, #####, cannot be added to the map." Additionally, when I copy the service URL and try adding it into AGOL to a new map, I am promoted with the same error message. I want to know if there is anything simple that I am missing with publishing data or do I need to contact ESRI Tech Support.
Things to Note:
ArcGIS Pro -- 2.0
Portal for ArcGIS -- 10.5.1
Server for ArcGIS -- 10.5.1
EricShreve
It appears that is the problem that you are running into. Do you know if the cert is signed by a CA?
Self-signed certs will have issues when you try to pass it through a browser.
MKF62
It's not right now, we're working on getting it signed. That's why I'm hoping it'll fix the issue!
MKF62
Just an update in case anyone else stumbles across this in the future: I changed our old certificate to the signed one and the problem resolved.
PersefoniKapotas
HELP.  I'm also having this issue suddenly.  "The Layer.......cannot be added to the map"  It started on Sunday (when we turned the clocks back).  I assumed that maybe this was the issue and decided to wait a while, but no luck.  I am attaching a screen shot of my console.  Can you help?  I am not working from home.
PersefoniKapotas
Also, I am working from Greece, just mentioning incase this may be part of the issue, although never caused a problem before.  I reset my router.  Nothing.  I am not savvy on the previous comments about ssl certificates etc. Although it doesn't appear to be a certificate issue based on the dev console.
EricShreve
Do you know if you CA certificate expired?
PersefoniKapotas
Thanks for responding.  It ends up that this was an issue from the data source.  Their servers were down!  All is good now.  Thanks.
