Enterprise User ID with a dash
2134
05-15-2017 12:40 PM
JanieGoddard
Will Enterprise User IDs with a dash create a new Portal Account correctly, when you setup Portal 10.5 using the IWA with AD accounts. It appears they will work correctly by this explanation.
Add members to your portal—Portal for ArcGIS (10.5) | ArcGIS Enterprise
Add members based on existing enterprise users
If your portal has been configured with an enterprise identity provider, enterprise accounts can be added individually, in bulk, or from enterprise groups managed by the identity provider. You cannot add enterprise accounts to your portal if it has not been configured with an enterprise identity store.
Accounts must include an email address in order to be added to the portal. Any special characters in account names will be changed to an underscore (_), except the at sign (@), point (.), or dash (-).
Add built-in portal accounts
However all the other directions explaining how to setup new users in Portal using built-in, one at a time, say differently. They say you can only add user-ids with an underscore.
account—The account is the user name to be used for the built-in account. Accounts must be between 6 and 24 characters in length, and they can only contain alphanumeric ASCII characters or underscores.
Janie
JanieGoddard
We do not have SAML. When we installed Portal, it gave us an option to add users in bulk from a csv file to our built-in user identity store. We were able to make this file using our current enterprise user ids which are first name dash last name. This upload did work with the dash in the user ids.
Janie
JanieGoddard
Janie
