But there are some problems found while migrating metadata. Run the repair tool to fix it.
1441
10-10-2019 05:43 PM
PierreMasson
We just did the Portal / ArcGIS Server federation, now we can'T add a Hosted Server because it says:
Unable to set gis.aquadata.com/arcgis as the hosting server.
Echec de la mise à jour du serveur fédéré 'xxxx.xxxxxxx.com:6443 (id: Q4usbCXA2Aactb89)'. Échec de la validation. Les serveurs d’hébergement exigent que le serveur ArcGIS Server possède une instance ArcGIS Data Store inscrite en tant que base de données gérée. Sélectionnez un serveur qui en utilise une.
Which can be loosely translated has:
Failed to update federated server xxxx.xxxxxx.com:6443 (id: Q4usbCXA2Aactb89) '. Failed validation Hosting servers require ArcGIS Server to have an ArcGIS Data Store instance registered as a managed database. Select a server that uses one.
So we install ArcGis Datastore, but when we run the configuration wizzard at the end we get this error:
La tentative de configuration du stockage des données a échoué.. Extended error message: Spatiotemporal data store upgrade completed. But there are some problems found while migrating metadata. Run the repair tool to fix it.
We tried the repair tool but did not work. I tried rebooting the server too, no luck.
We are at lost and losing money by the hour. Please help.
