audit sharing for all portal items
1436
06-06-2022 04:05 PM
forestknutsen1
Is it possible to  audit the sharing level for every item in portal without browsing to each item? Perhaps with the rest API?
jcarlson
MVP Esteemed Contributor
It could be easy enough with the Python API.
import arcgis
gis = arcgis.GIS('your url', 'user', 'password')
items = gis.content.search('-owner:esri -owner:esri_apps', max_items=-1)
for i in items:
    print(i.title, i.shared_with)
If you like, you could have this write to a text file instead of simply printing each line, but this should give you a good starting point.
- Josh Carlson
Kendall County GIS
Brian_Wilson
Honored Contributor
Yes, sharing information is exposed in the REST api and I have done complete inventories of my site with the Python API.
jcarlson
import arcgis
for i in items:
- Josh Carlson
Kendall County GIS
Brian_Wilson
Honored Contributor
Comment on @jcarlson's elegant query.
That "everything but esri" query is critical, otherwise you will get hundreds of useless-to-you results back that are from the Esri catalog. The default max_items is 500 and without the query string you will always get back 500 items. I found that very confusing at first.
forestknutsen1
That did it all right! Thanks @Brian_Wilson  and @jcarlson.
I also needed to exclude the esri_nav user from the search.
jcarlson
I think you're allowed to delete the esri_nav stuff, aren't you? It's just the other two that you're stuck with. I seem to recall removing all those, hence the omission from my query.
- Josh Carlson
Kendall County GIS
