11.5 upgrade cache issues
5518
10
07-11-2025 01:40 PM
BrantGossett
Since upgrading from Enterprise 11.1 to 11.5, we've encountered several issues—many of which appear to be related to ChunkLoadError. I've tested across multiple browsers, and behavior varies between them.
In some cases, maps or specific elements fail to load in Dashboards; other times, tables won’t appear in Experience Builder’s table widget. Performing a hard reload and clearing the cache temporarily resolves the issue—missing components will reappear—but the problem tends to resurface later the same day in different dashboards or apps, requiring the same steps again.
The issue appears to be random, with no consistent pattern in terms of when or where it occurs, and it’s not limited to a particular browser.
SimonSchütte_ct
MVP Regular Contributor
Josh_Hawkins wrote: Esri  "mentioned that a software patch named Portal for ArcGIS 11.5 Web Applications Patch will be released soon to resolve this defect." and provided a preliminary fix:
Solved: Re: Content failing to load completely - Esri Community
KimiaK
by Esri Contributor
Thank you for bringing this to our attention. We are aware of this issue and are actively working on it as a high priority. Defect number BUG-000177808 has been logged for this specific issue.
BUG-000177808: Web applications such as ArcGIS Sites and ArcGIS dashboards intermittently fail to load UI elements with an error in the browser console 'ERROR: ChunkLoadError: Loading chunk xxxx failed.' due to JavaScript chunk files getting cached on the local disk cache as empty files.
We appreciate your patience while we address this matter. If you are encountering this issue, please submit a case with Technical Support.
BrantGossett
I received an update stating this bug wont be fixed until version 12? Is that right?
Marshal
Eagerly awaiting a response to this question.  Having to wait until version 12 is released to fix broken web applications would be a crazy response.
lvargas
This happened to us after upgrading an environment from 10.9.0 to 11.5. After that, we experienced issues with maps, Experience Builder, Dashboard, etc. It's great that you were able to identify the problem and log a bug to work on a solution.
Andrew-Bowne
Same issues happening here. Mostly in ExB.  We are also seeing React errors.
Marc_Graham
Hi @KimiaK
I am planning an upgrade from 11.3 to 11.5
This issue has me concerned. I would like to upgrade knowing a patch is coming.
Can you please confirm if this will be addressed in a patch soon, or if it will be delayed until ArcGIS Enterprise 12?
Marc
GarrettJohnson
Please confirm if patched before version 12?
SimonSchütte_ct
pkorst_coa
Do you suppose this bug is causing the issue with enterprise portal 11.5 where dashboard elements (map, charts) will intermittently fail to display in MS Edge but typically display fine in Chrome and Firefox?
