Enable HTTP access to multi-machine ArcGIS Server site in Azure Application Gateway?
741
12-28-2021 11:39 AM
ThomasIsraelsen
Please advise on which changes I need to make to the Azure Application Gateway created by the Azure Cloud Builder for 10.9.1 in order to enable support for HTTP.
I have successfully deployed a 3-machine ArcGIS Server site, which works fine with HTTPS, but for a while yet I need support for HTTP for some legacy customers, that I am moving from AWS.
HTTP works fine in Azure, if I install ArcGIS Server manually in an Azure VM without using the Azure Cloud Builder, but I want to use the builder since it provides some needed features in how it sets things up in the Application Gateway.
