Create Enterprise Geodatabase on Clous SQL Google Cloud Platform
1041
02-18-2025 03:28 AM
vais
Hello,
I need to use a Postgres with our ArcGIS Enterprise and Utility Network.  We have the possibility to use a C loud SQL Postegres from Google Cloud Platform, but we know that in this scenario it's impossible to install the st_geometry.dll
So the question is: The enteroprise geodatabase (so the Utyility Network) is supported on Cloud SQL Postgres from GCP?
Thanks
George_Thompson
Esri Notable Contributor
It looks like this would be supported as long as the version of PostgreSQL is supported: https://enterprise.arcgis.com/en/system-requirements/latest/windows/databases-in-the-cloud.htm#ESRI_...
"Because you cannot load the ST_Geometry library to a database-as-a-service offering, only the PostGIS spatial types are supported when using Amazon Aurora (PostgreSQL-compatible edition)Amazon RDS for PostgreSQLGoogle Cloud SQL for PostgreSQL, and Microsoft Azure Database for PostgreSQL (all options), and only the SDO_Geometry spatial type is supported when using Amazon RDS for Oracle or Autonomous Transaction Processing."
--- George T.
