Cloud builder visual c++ requirement using windows on macbook with m1 chip
1394
12-16-2023 11:20 PM
omar-marji
Trying to install enterprise cloud builder 11.2 on a MacBook Pro with M1 chip running windows 11 using the latest parallels version, but the installation does not start and always complains that it does not find the Microsoft Visual C++ Redistributable for Visual Studio.
The latest 64 bit version is definitely installed but for some reason the installer is unable to recognize it. Is there a way around this? I am suspecting it has something to do with the apple silicon but I am not sure if there is any way  around it. I tried installing the ARM version as well, but got the same results as well.
DevinBartley2
You are brave to be using M1 with Parallels to do this type of work, as I assume it is not explicitly supported by ESRI. My solution would just be to spin up a windows machine in the cloud or buy a cheap used windows machine instead of trying to get things to run with your M1 chip. Good luck and keep us updated if you get it working.
