Can't deploy Portal using cloud builder
1225
11-19-2021 02:08 PM
JoeSaltenberger
I get the following error when deploying ArcGIS Enterprise using the Azure 10.9 cloud builder:
"PowerShell DSC resource ArcGIS_Portal failed to execute Set-TargetResource functionality with error message: The license file is invalid. The version 10.9.1 of the selected file is not supported at your software version 10.9.0."
The license file I have for ArcGIS Server is for 10.9/10.9.1 and the Portal license file I have is for 10.9.1. It looks like ArcGIS Server deploys properly because I can access ArcGIS Server Manager, but I can't access ArcGIS Portal.
Is the Azure 10.9 cloud builder not able to handle a 10.9.1 Portal license? If not, can I authorize Portal directly on the VM after install? I prefer to use the cloud builder, but it doesn't look like the Azure 10.9.1 cloud builder has been released yet.
Thanks.
ABishop
I would install everything to match.  ESRI doesn't like when you try to mismatch versions of anything.
Amanda Bishop, GISP
