Add features/extensions to an ArcGIS Enterprise 11.3 deployment on Azure, how?
732
11-04-2024 01:57 AM
PanGIS
Hello!
I am testing a deployment in Azure, and I am still figuring out things as the only deployments I have worked so far are on physical machines.
I deployed using the cloud builder for Azure, single machine, 11.3, I did not set up a remote access.
I now need to extend the Server license to Data interoperability, and I need to install the FME Package...how can I do it?
Since there is not remote access set up am I stuck? this is a more general question, what do I need to do if I need to tackle these kinds of issues in the future?
Thanks!
Yogesh_Chavan
Hello @PanGIS
Did you simply tried getting the downloader into the machine and installing it manually?
https://enterprise.arcgis.com/en/documentation/install/data-interoperability/latest/arcgis-data-inte...
PanGIS
Hi @Yogesh_Chavan the problem is that I don't know how to access the machine. As I said I am still new to Azure and I am still figuring it out.
As I said, I did not  "Enable remote desktop access using a jumpbox port" and I don't know if I had to do that.
in My Azure I tried to access and I can't, not sure what is the cause.
