View dependent services
1523
01-05-2013 07:55 AM
MikeSchonlau
It would be very helpful if there was a tool that would tell me which ArcGIS Server services are currently accessing a specific feature class. When I need to make a schema change, I end up having to stop all of my services to do it.
2 Comments
NeillJobe
Our Admin Tools for ArcGIS Online (Pro) & Portal will show you item dependencies in this fashion. You can even print out the hierarchy so that you can reference it later. Here is a video that gives you a very quick run down - https://youtu.be/S1CvjZrWn3M
Here is a link to the ArcGIS Marketplace - https://marketplace.arcgis.com/listing.html?id=4b9205d08a42413085a17ca91b97e3c7 - See more at: https://c.na9.visual.force.com/apex/ideaView?id=087E0000000Cxj0IAC#sthash.H8wk7gRz.dpuf
jill_es
