Support the OAuth2.0 token_exchange grant_type
1484
10-25-2023 05:32 AM
Status: Open
Fedor_Haaker
We like to use ArcGis Portal in our Microservice environment. This environment uses API Management to give access to all the microservices with one token that is acquired through the API management system with the use of our Azure AD identity provider. The OAuth2.0 grant_type that is used here, is token-exchange (https://www.rfc-editor.org/rfc/rfc8693.html). Because ArcGis Portal doesn't support the grant_type: token-exchange, the users of client applications on our Cloud Environment have to do a extra login for our Portal environment bij choosing an identity provider in a pop-up screen.
With ArcGis Portal it is therefore not possible at this moment to use it in a scenario with API gateways or API-to-API communication.
Therefore we would like to propose an enhancement for ArcGis Portal where Portal does support te token-exchange grant-type.
A second enhancement dat we would like to propose is the ability to set a default identity provider depending on a parameter in the url so the user is automatically switched to de identity provider that is meant for him. This way the user doesn't have to choose between the build-in and Azure AD identity providers.
1 Comment
NicolasGIS
Completely agree with you !
Currently this limitation makes the integration of a small map component in a big application where the user is already logged not ideal with the only supported code flow. Specially with the new support of OIDC, if the backend application have already an IDToken for the user,  it would be nice to be able to get an ArcGIS Token by prodiving this IDToken (urn:ietf:params:oauth:token-type:id_token):
https://curity.io/resources/learn/token-exchange-flow/
