ST_GEOMETRY function to remove M and/or Z values
2276
04-14-2022 10:41 AM
Status: Open
Bud
Legendary Contributor
Could a function be added to ST_GEOMETRY to remove the M-dimension from a geometry?
Similar to SDO_GEOMETRY's CONVERT_TO_STD_GEOM function:
SDO_LRS.CONVERT_TO_STD_GEOM
Converts an LRS geometric segment to a standard SDO_GEOMETRY line string by removing measure information.
2 Comments
Bud
We also need to be able to remove the Z dimension from ST_GEOMETRY.
Related post here:
I need to remove Z dimension on spatial column (ST_GEOMETRY) with Esri on Oracle using the PL/SQL pa...
Bud
For anyone who doesn’t want to wait for this to be implemented, here are some ideas for a temporary workaround:
Convert the ST_GEOMETRY to WKT, manipulate the WKT ordinates, convert back to ST_GEOMETRY.
Note: We might lose some information from the SHAPE if we did that, such as losing true curves, since true curves are only stored in the shape blob, not in the ST_GEOMETRY portion of the SHAPE column. What column is true curve data stored in? (SDE.ST_GEOMETRY for Oracle)
In other words, the ST_GEOMETRY constructor function that we’d use to update the SHAPE would replace the entire SHAPE value, so the shape blob with true curves info would be lost.
Links:
I haven’t had a chance to test those ideas.
