ST_Geometry: Function-based spatial indexes
1341
05-10-2022 09:28 AM
Status: Open
Bud
Legendary Contributor
With Oracle's SDO_GEOMETRTY, we can create function-based spatial indexes that vastly improve performance for computed geometry columns.
Could Esri add that functionality for SDE.ST_GEOMETRY in Oracle?
1 Comment
Bud
For what it's worth, I can in theory create a ST_GEOMETRY function-based spatial index:
create index atn_startpoint_shape on infrastr.active_transportation
(sde.st_geomfromwkb(sde.st_asbinary(sde.st_startpoint(sde.st_geometryn(shape,1))),300125))
indextype is SDE.ST_SPATIAL_INDEX parameters ('ST_GRIDS=320 ST_SRID=300125');
Index ATN_STARTPOINT_SHAPE created.
But there doesn't seem to be a way to utilize that index in the map in ArcGIS Pro. For example, I wouldn't insert a row into USER_SDO_GEOM_METADATA for ST_GEOMETRY spatial index, since that's designed for SDO_GEOMETRY columns only.
When I try to test a view that would use the index in ArcMap...
create or replace view atn_startpoint_vw as (
select
objectid,
sde.st_geomfromwkb(sde.st_asbinary(sde.st_startpoint(sde.st_geometryn(shape,1))),300125) shape
from
where
sde.st_geomfromwkb(sde.st_asbinary(sde.st_startpoint(sde.st_geometryn(shape,1))),300125) is not null
...it just crashes.
Similar to this issue: ArcGIS Pro crashes when copying Oracle view to FGDB.
Equivalent to USER_SDO_GEOM_METADATA for SDE.ST_GEOMETRY? (function-based spatial indexes)
