SAML Portal Auto-Login
1611
03-06-2024 01:01 PM
Status: Open
BenjaminRitter
Allow the ability to auto-login to Portal when using SAML, similar to when using IWA, especially when there is only 1 security login type enabled (ie: built-in account login in disabled). What is the point of SSO if you have to click on a button on the sign-in page to log in when it could just automatically "click" the button for you and sign you in after authenticating.
2 Comments
JeffSmith
@BenjaminRitter This auto-login process you are describing has been available in Portal for quite a while.  If SAML is the only enabled login type, you should be automatically redirected to the SAML login after you click the "Sign In" button.  What release are you testing this on?  If you want to eliminate even having to click on the "Sign In" button, you can disable the "Allow anonymous access to your portal" option under Organization > Settings > Security.
BenjaminRitter
@JeffSmith Thanks. I was able to figure it out. This can be marked in already implemented.
