Not use in Field Map as default when creating a new Web Map
794
03-05-2024 01:12 AM
Status: Open
Ann-KristinKristensson
Hi
When I make a new Web Map I would like if the default setting for it to show i Field Map would be Not.
Most of the Web Maps that I create is not for show in Field Map, so now I have to remember  to go to the Map settings and remove that option when I make a new Web Map
It would be better the other way round, if I want the new Web Map to show up i Field Map then I´d have to make that option i the Map settings
Thanks
Ann-Kristin
1 Comment
CalvinHarmin
Linking another duplicate idea thread. We also believe this should be a simple option to set default, in both Enterprise and AGOL.
https://community.esri.com/t5/arcgis-enterprise-ideas/set-web-maps-to-not-be-visible-in-field-maps-b...
