Bulk publishing select layers to publish or unpublish
912
12-19-2023 07:27 AM
Status: Open
Joshua-Young
MVP Regular Contributor
I think it would be helpful to have a new interface when bulk publishing that allows a user to select which layers should be published, unpublished, or synced. When setting up bulk publishing have an interface that shows all the datasets available through the database connection with three different options associated with each dataset depending on its status. One option for publishing, another for unpublishing, and a third for syncing. Then have a way to select multiple datasets plus a select all/unselect all button. That way users can manage the datasets in bulk or individually as is needed.
I have found that initially the publish everything available to the database connection is great, but after that I need to make small adjustments to individual layers over time and not everything all at once.
1 Comment
NinaRihn
I agree... our problem is, we have a very large enterprise database, and any given connected user could have access to a LOT of data they should not be publishing, therefore we can't use the Bulk Publishing option at all since we have no control over which things are getting published.
