ArcGIS Server REST API Support BLOB Fields
3281
05-14-2013 07:31 AM
Status: Implemented
MichaelVolz
Esteemed Contributor
I have a 3rd party GIS application that adds images to a SQL Server database via a BLOB field.  I want to be able to easily access these images in their native format in the BLOB field from an ArcGIS Server based application.  Unfortunately, the ArcGIS Server REST API does not support BLOBs.  As such, the current workaround is to store the images in another format that can be read by the ArcGIS Server REST API, which results in duplication of storage.  From other ESRI forum posts, I can see that there are other 3rd party GIS applications/vendors that store data in BLOB format so I'm sure this would be useful for other developers as well.
3 Comments
DustinWiersma2
This would be most helpful!
MaximeDemers
If you are using a GPService to access your images, you could encode them in base64, so it will be passed as strings through the REST API.
jill_es
This is currently possible in ArcGIS Enterprise.
