Spatial Join with AGS Server
1415
08-17-2020 08:30 PM
RamakrishnaBillakanti
SOE for sptaial join. I want to get the attributes of a line features which overlay a particular polygon. Is it possible to get this functionality without custom SOE if not can anyone point me to an SOE which if exists already in the dev blogs. Thank  you.
nicogis
You can use rest api using query ( Query (Map Service/Layer)—ArcGIS REST API | ArcGIS for Developers  ) . In geometry parameter you put the polygon
