SOE 10.3.1 Forward Compability
5321
04-10-2016 10:16 AM
MeleKoneya
We are upgrading our ArcGIS server 10.2.2 to 10.3.1.
We have two SOEs that are needed once we upgrade.
I am trying to ensure that there will be no issues when I upgrade.     According to ESRI I only need to remove the SOEs prior to the upgrade and then add them back after the upgrade.
My question is do I need to upgrade the ArcObjects SDK prior to upgrading the ArcGIS Server installation and adding the SOEs back?    The SOE uses the SOESupport assembly which I believe comes from the SDK and that is why I was wondering if the SDK needed to be upgraded.
I am assuming that because my SOE is currently working in 10.2.2 that .NET 3.5 SP1 is installed,  correct?
Thanks for any input.
Mele
nicogis
If you have created a soe with 10.2.2 and you need use it in 10.3.1 you don't need upgrade soe.
10.3.1 uses .net 3.5
During installation you select .net extension support
