serverobject becomes null in SOI
2368
06-08-2021 07:18 AM
AndreasRuloffs2
I have written an SOI for rights management in c# and let it run on ArcGIS server 10.7.1.
Normally it is working good, but sometimes the Service becomes unavailable. In the Log files I find the message:
<Msg time="2021-05-31T10:13:27,277" type="SEVERE" code="9000" source="Rest" process="4724" thread="1" methodName="" machine="MU-KARTENSRV.REGIONHANNOVER.DE" user="" elapsed="" requestID="feed7716-61c9-4107-ad25-5133bfcc1d58">Error performing query operation Error handling service request :0x80004003 - Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt. in 'GlobalNetXXSOI'</Msg>
The error message says, that there is a null pointer.
The translation of the germen massage should be:
"Object reference not set to an instance of an object"
I have a class attribute:
private IServerObject serverObject;
 Like in the esri samples it is filled in the init method:
    public void Init(IServerObjectHelper pSOH)
            try
                serverObject = pSOH.ServerObject;
            catch (Exception e)
                logger.LogError(e);
                Logger.WriteSystemError(e.ToString());
 But now it seems, that this attribute becomes null some times. Is there any way I could get the ServerObject, outside the Init method, so I could restore it, when it becomes null?
Best regards,
Andreas Ruloffs
nicogis
MVP Alum
get IServerObjectHelper in init
The server object helper implements a weak reference on a server object such that a server object extension can keep a string reference on the server object helper (for example, in a member variable) and avoid keeping a strong reference on the server object itself.
AndreasRuloffs2
Thank you for your answer,
OK, so I will change it, that I keep the helper in a member and access the serverObject from it.
But I am afraid, this wont fix my problem, cause I had the problem when I had solved it this way some time ago.
