Migrate Built-In Named User accounts to Enterprise Named User accounts (Active Directory/SAML) in ArcGIS Enterprise/ArcGIS Online
23878
35
03-21-2023 10:51 AM
The below video will walk through migrating built-in named user accounts to enterprise named user accounts within ArcGIS Enterprise/ArcGIS Online using the attached scripts.  The enterprise accounts can be SAML or, for ArcGIS Enterprise, Active Directory (IWA).
Note:  My Esri training will not be maintained for AGOL accounts
The below script will print which users have Esri Access enabled.  To maintain training, these users should be removed from the CSV and migrated manually.  See the following link for more details for users that have Esri access enabled.
from arcgis.gis import GIS
gis = GIS('https://www.arcgis.com', username, password)
all_users = gis.users.search()
for user in all_users:
    if user.esri_access == 'both':
        print(user.username)
Comments
PeterKnoop
MVP Regular Contributor
@JakeSkinner great script! I think there might be one minor thing you've overlooked: the user's Group role (Member or Group Manager) in a group. For example, in "ArcGIS Online - Migrating User Content and Groups.py", around line 175, you would want to check the group role of the user's built-in online account, and assign the same group role to the user's enterprise account when you add them to the group (usernames = Member and admins = Group Manager.)
Also, for anyone using this script to process a very large lists of accounts, you run the risk of exceeding the operations rate limit, and the possibility of the script failing part way through processing a user. For such a case, I would highly recommend sticking a 5-second sleep in between processing each user.
JakeSkinner
Esri Esteemed Contributor
@PeterKnoop good catch on adding the users to Groups.  I've updated the scripts to add them as either users/managers.
ErikNelson1
@JakeSkinner  Thank you for the script!
We are coming across issues connecting to our Enterprise portal in the Get Built-In Users Script. We tested several variations of our portal's url but we have been getting errors. We are trying to run the script on a virtual machine in our ArcGIS Enterprise environment. When using our portal url and portal admin credentials we are getting this error:  "Exception: User not allowed for this account (Error Code: 403)". We tried adding the ':7443' port to the url and it times out and gives us the same error.
Example of what we have been using: gis = GIS(url="https://gis.organization.com/portal", username="username", password="password", verify_cert=False)
We also tried to add portal server's IP address in combination with the port number which looks something like :
gis = GIS(url="https://Portal IP Address:7443/arcgis", username="username", password="password", verify_cert=False)
but we get the following error:
"Exception: A general error occurred: Could not login. Please ensure you have valid credentials and set your security login question."
Any guidance or suggestions would be greatly appreciated as we cannot seem to get past the initial step of connecting to the portal url in the built-in users script that you have shared.
JakeSkinner
@ErikNelson1 what type of account are you using to connect to Portal?  Do you know if it's a built-in, active directory, or SAML?  SAML is not currently supported.
ErikNelson1
@JakeSkinner we are using a built-in admin account to connect to the Portal.
JakeSkinner
@ErikNelson1 do you have a security question set for the built-in account you are using?
ErikNelson1
@JakeSkinner yes, we do have a security question set for the built-in account we're using
JakeSkinner
@ErikNelson1 ,
1.  Are you able to sign into Portal with the credentials you are providing in the script?
2.  Do you have any reverse proxies in place?
3.  Is there another built-in admin account you can try?
ErikNelson1
@JakeSkinner
  • Yes, we are able to sign into our Portal with the admin credentials we've entered in the script.
  • We do not have reverse proxies in place.
  • We tested creating another built-in Portal admin account, setting the security question, and using those admin credentials in the script but we're still encountering the same errors.
JakeSkinner
@ErikNelson1 can you test the below code on another machine that has ArcGIS Pro installed:
ErikNelson1
@JakeSkinner  we determined that our python environment did not match our 10.9 Portal version.
The script ran successfully after running it in a python environment that was compatible with our Enterprise version.
TarigAhmedTXHSDS
Thank you so much for the video and scripts.
We are preparing to move to IAMOnline authentication.
When I ran the script to get the users for Portal. I noticed the Apps column is empty!
Could you please help me?
Best regards,
Tarig Ahmed, GISP | GIS Administrator
SHARP DSHS-IT Analytics Team
[email protected] |  469-261-0849
DSHS ArcGIS Online | DSHS ArcGIS Enterprise Portal
JakeSkinner
@TarigAhmedTXHSDS,
This column should be populated if you have any Application licenses (i.e. ArcGIS Pro, Insights, Field Maps, etc) assigned to the user.  Ex:
Thomas_Puthusserry
@JakeSkinner I am trying to use the scripts to create a new user in AGOL and transfer the contents.
Step1. Created the built-in user list successfully. Used a built-in admin user account
Step2. Tried to create a new user ID from the list, for one user. However it failed. The message is:
Creating new standard user with id: [email protected]_agol_shortname
Unable to create [email protected]_agol_shortname
Tried with variations of the new username, but no success.
What could be the issue?
JakeSkinner
@Thomas_Puthusserry are you able to manually create the user [email protected]_agol_shortname?
GISLondon
New Explorer
Yes, that works manually
Thomas_Puthusserry
@JakeSkinner
I just tested this and it worked. I assume there is no restriction in the length of the user name?
JakeSkinner
@Thomas_Puthusserry within the CSV, remove the agol shortname from the new username.  See if that works.
Thomas_Puthusserry
@JakeSkinner That was something I tried. Couple of different combinations, but nothing seems working (used a short email: [email protected]) but same error
Thomas_Puthusserry
@JakeSkinner The main idea behind using your script is to move the users to SAML authentication. However the AGOL org where I tried your script, the SAML authentication part is not yet configured. Wonder whether there is any such requirements  prior to migrating users?
JakeSkinner
@Thomas_Puthusserry yes, I believe this may be a requirement for you to successfully create the SAML account.
Thomas_Puthusserry
@JakeSkinner After enabling SAML in the AGOL, the script is running and new user is created and all items / groups  transferred to the new account. However the new user cannot login: get this error:
However, if I add a new user to connect via SAML then it works, which means the setup is correct. So why is that the user id created with script is not enabled to login?
JakeSkinner
@Thomas_Puthusserry do you see any differences with the user accounts created from the script, and the one created manually?  A customer I'm working with ran the same script last week and noticed the SAML account created via the script did not append the _agolshortname to the SAML account since they did not have that specified in the CSV.  However, the account still worked without the shortname.  This may be different for different SAML IDPs, though.
Thomas_Puthusserry
@JakeSkinner  thanks for the quick response, appreciated.
Obviously, when I created the account via script, the agolshortname was appened (email_agolshortname) after the email and therefore the account is fine.
The account created manually, when the user email is given in the 'User Identifier' field, in the next screen it automatically adds the agolshortname. With that the user can login via SAML
Now I have tested what you said above: Created a new built-in user with agolshortname appended. In the csv, didn't add the agolshortname (just email). Ran the script which created the new user with just email and assigned to groups etc. This user can login via SAML. However I got some traceback error related to old user, but nothing an issue.
Does this mean that the IDPusername (email) cannot be used in another AGOL account?
DCWade
@JakeSkinner We are testing the API 2.4.1 and later scripts and are running into an error with the migration script. If a user owns content we are getting an AttributeError: 'dict' object has no attribute 'name' error at if folder.name != 'Root Folder: (line 185 in the ArcGIS Enterprise script, line 203 in the ArcGIS Online script).
It looks like folder.name is still an active arcgis module so I'm not sure why this line is flagging?
JakeSkinner
@DCWade what version of ArcGIS Pro or ArcGIS Server is installed on the server where you executing the script?
DCWade
@JakeSkinner For the Enterprise script we are on ArcPro 3.1 and Server 11.1, but the ArcGIS Online script is failing for our AGOL accounts as well.
I was able to get the API 2.4.0 and earlier scripts to run in both environments, and in those the folder section does not call the "name" property. Not sure if anyone else has experienced issues with that
JakeSkinner
@DCWade since you are at Pro 3.1 and Server 11.1, you will want to use the 2.4.0 and earlier version of the scripts.  Once you upgrade to Pro 3.4 and/or Server 11.5, the ArcGIS API will upgrade to 2.4.1.
VenkataKondepati
Honored Contributor
This is a very useful guide. Migrating built-in named users to Enterprise accounts can be tricky in federated environments, and having clear steps helps avoid common pitfalls — especially around account mapping and identity linkage. Thanks for laying out the workflow and considerations in one place.
– Venkat
DavidColey
MVP Frequent Contributor
Hello @JakeSkinner - can you tell me where the module Logger comes from?
from Logger import Logger
when I try to run the script (api > 2.4.1) for Built-In ArcGIS Online users in the Python IDLE the Logger module is not found.
I do not have Visual Studio or VSCode installed at the moment.
I am on Pro 3.6x.
JakeSkinner
@DavidColey there's a Logger.py included with the zip file.  This file has to exist in the same directory as the other scripts.
DavidColey
Ok thanks @JakeSkinner  -
This is what I see in the api documentation now:
https://developers.arcgis.com/python/latest/guide/advanced-concepts/
import logging
import sys
# Create logger
logger = logging.getLogger()
logger.setLevel(logging.INFO)
will setting logging like this at the top of the GetUsers and Migrate scripts work in place of using the Logger.py file?
DavidColey
Scratch my reply @JakeSkinner  - I now see that the Logger.py is setting up the classes and definitions and environments....
Thanks again!
MikeFallon
@JakeSkinner We are testing the API 2.4.1 and later scripts with ArcGIS Online and are running into an error with the migration script. If a user owns content we are getting an AttributeError: 'dict' object has no attribute 'name' error at if folder.name != 'Root Folder: (line 201 in the ArcGIS Online script).
JakeSkinner
@MikeFallon what version of ArcGIS Pro are you running?
Version history
Last update:
‎11-22-2025 01:50 PM
Updated by:
Contributors
