Relative datapath in config.xml
2047
03-25-2019 03:42 AM
MalikThrane1
Is it possible to set relative datapath in the config.xml?
As with:  <layer name="Data1" type="TilePackage" url="..\Data\Elevation\Data1.tpk" state="Visible"/>
If it is, how to do it? So far I haven't been able to succeed.
Best regards
Malik
Mandy_Li
Hi Malik,
Relative data path in the administrator's configuration file is NOT supported. If you, as an admin, are trying to configure startup layers for your organization, could you check if the data path specified is accessible (at least readable) by other users in your org?
Example:
<layer name="startup_tilepackage" type="TilePackage" url="D:\test.tpk" state="Invisible"/>
Mandy
MalikThrane1
Hi Mandy,
Thank you for the reply. Do you know if relative paths will be supported at some point?
Yes, the data is accessible for other users when I write a specific file path in the config-file, as eg. url="D:\test.tpk" .
Best regards
Malik
Mandy_Li
Hi Malik,
There is a plan to redesign the 'administrator configuration' workflow at 2019Q4 or 2020Q1, with the intention to provide a more intuitive user experience and simplify the configuration process. We might be more cautious about adding new enhancements at this point. Your feedback will certainly be considered.
Have a good day!
Mandy
MalikThrane1
Hi Mandy,
Sounds interesting, looking forward to that
Have a nice day too!
Malik
