How do I create an animation if time interval is on the column
886
09-04-2019 07:12 AM
Pai-FengV
Hello everyone,
I am currently working on the animation of the change of water storage at the watershed. Currently I successfully created the map that attached the change of water storage to the map I wanted.
However, here is the problem: the changing time is on the first row instead of column, and the "time" function on the ArcGIS can only make column into the time slide or animation.
Here is the sample.
The screenshot that shows the table of my map. It shows that the time is on the top row and I can
The time is the first row. I must find a way to either transpose it, or convert this shapefile into multiple files with only data for each month.
Is it possible? Thank you.
