ArcGIS Earth Select a certificate
1543
07-25-2023 10:47 AM
DavidNugent2
My organization has recently decided to upgrade to ArcGIS Earth 2.0 and we are being prompted to Select a certificate but everything is more or less greyed out. The application was working fine at 1.16 using a custom configuration file with no pop-up and we were able to connect to our enterprise environment. We are able to connect to Enterprise through Pro, Field Maps and even our Python environment. Does anyone have any tips?
XiChen
by Esri Contributor
Hi @DavidNugent2,
Thank you for bringing this issue to our attention. To better assist you, could you provide more details about the problem?
  1. A video of the workflow where the issue occurs would be very helpful.
  2. Screenshots of the "Select a certificate" prompt in Pro for us to compare the difference.
  3. Any error messages or logs you might have encountered.
These details will help us get a clearer picture of the issue and guide you more effectively.
Thank you for reaching out, and we look forward to assisting you further.
