Strange behaviour when upgrading to 10.6 (Desktop)
924
02-07-2018 07:11 AM
PanGIS
Hi guys,
I upgraded a bunch of 10.2 desktop to 10.6 without problems.
I had only one 10.1. with a License Manager with the same version not licensed and  not being used.
I uninstalled the license manager 10.1.
I almost sure that 10.1 is included in the target system but maybe I am wrong.
but when I started the installation I was prompted to uninstall the 10.1 in order to continue.
I didn't do it: I upgraded from 10.1 to 10.4.1 and then to 10.6. --- > OK
Do you think something was left behind from license manager?
Why the installation was detecting the 10.1 as a problem
Also,
When closing the mxd I got the following
in System32 there was no Normal.mxt
I know it is supposed to be in appdata/esri/roaming/destop10.x/arcmap
In Desktop10.6 there was only Catalog and the addInFolderList . Nothing else.
I could save the mxd but still, after I opened again a new mxd I got this at closing?
The normal.mxt was not created at all.
(I checked the 10.1 folder and all the default folders were there as it should be.)
Any clue?
Tags (3)
