LOADING DOCUMENTS, START UP, ARCMAP 10.6.1
3514
6
03-15-2022 07:52 AM
Daniel_Grellet
Hi!! I have problems with ArcMap 10.6.1 at start up. It Freeze when "LOADING DOCUMENT..." screen apperars. I saw other posts solving this problema, but no one could help me. I decide to reinstall de soft but still with problems. THX!!!
SteveCole
Honored Contributor
It could be that your normal.mxt has gone corrupt. Go to this folder on your c: drive:
C:\Users\<your user name>\AppData\Roaming\ESRI\Desktop10.6\ArcMap\Templates
...and rename the normal.mxt to normal.bkp or something else. Now try restarting Arcmap. The application won't find the normal.mxt so it will make a new one and then finally (hopefully) open up.
Daniel_Grellet
Thx Steve, but still with that problem...
DavidPike
MVP Notable Contributor
Sounds like a corrupt MXD if trying to open, give Using the MXD Doctor utility—ArcMap | Documentation (arcgis.com) a try.
If it's just the application loading on it's own and normal.mxt or fresh install haven't worked, something funky is going on with your system, C++, .NET possibly?? (not helpful I appreciate).
Daniel_Grellet
Thx David!!! I have another problem. I need to improve the performance of Stored Displays. Any suggestion? I would be very grateful if you can help me.
DavidPike
Did that fix your original issue?  I'm not sure what stored displays are. Perhaps Managing your local display cache—ArcMap | Documentation (arcgis.com)
Daniel_Grellet
The only solution was re-installing the soft. Thanks David!!!
