License Manager via Wireless
4338
06-17-2015 11:54 AM
DiegoLlamas
I have a question. If I have a lab with 31 licenses centralized in a License server. Is it possible that my client computers consume the licenses via wireless? is it possible?
thanks for your help!
DLL
RebeccaStrauch__GISP
I assume this is a concurrent license manager?   If so, also assuming your network (suggest secure) wireless modem is set up correctly, this should work.  You may need to have a port open in you network, and if so, there are many threads on Geonet on how to specify an external post with you license manager files.
i actually access​ our license manager thru my secure wireless modem from home....although our IT will be removing the open port so this will be going away for us. (bummer)
DiegoLlamas
Thanks Rebecca, it is good to know that there is an other alternative for connecting to License Server Manager.
Diego, if that answer works for, don't forget to mark it as answered so the question is closed. ​
