Hi, Is there anyway I can fix this problem without reinstalling ArcGis?
1628
02-16-2018 06:55 AM
SaadIbrahim
RobertBorchert
Honored Contributor
Try doing a search of your entire HDD for the .dll in case it accidentally was moved.  Check your recycle bin for the .dll
if you find it then it should be placed in the bin directory of your ArcGIS install location.
if you used defaults it should be
C:\Program Files (x86)\ArcGIS\Desktop10.5\bin
or whatever your current version is.
DanPatterson_Retired
In Control Panel, Go to the Add/Remove programs section and try a 'Repair'
