Conflicting messages about spatial analyst license
1742
02-16-2020 02:57 PM
DavidVesely
I've been trying to use spatial analyst tools in ArcMap. I've got a current license for Spatial Analyst and I can confirm this in the ArcGIS Administrator. Ver. 10.1-10.7 is installed and authorized until 12/3/2020. However, when I try to open one of the tools, I get the message, "Unable to execute the selected tool. You do not have the necessary license to execute the selected tool. ERROR 010096.".
Can someone explain how ArcGIS Administrator thinks I have a license for Spatial Analyst and ArcMap says I don't?
UriGilad_EsriAu
Did you enable the Extension? Go to Customize - Extensions and tick the Spatial Analyst box.
If you found this answer helpful or if it solved your question please mark it accordingly to help others who have the same question.
DavidVesely
Yes, Spatial Analyst extension is enabled.
DavidPike
MVP Notable Contributor
Is this a default tool or one of your own?
Perhaps resetting the normal.mxt might solve it.
DavidVesely
It happens for any of the tools in Spatial Analyst or 3D Analyst. I could try that reset, although I don't have much hope in that.
