ArcMap 10.5 crashing when using the Attribute Assistant Add-in
729
09-19-2018 02:02 AM
MalardArnauld
I installed the last version of "Attribute Assistant" this morning running with ArcMap 10.5
Each time I activate the tool - ArcMap suddenly get slow, starts freezing after a few minutes and finally crashes... Even if I don't turn on the Add-in?...
It's a bit disappointing.... Does someone encounter the same problem?...
