ArcMap 10.2.2 Exception thrown in destructor
28286
27
07-15-2015 07:33 AM
GabrielYarlequé
I was having issues with arcmap and opening mxd files. This is what I got. The mxd wasnt the problem because I was able to open on another machine.
So I decided to update to 10.2.2. Tried to open the same file and no luck. Then I tried creating a new mxd file, and this time the add data button was grayed out. So I decided to repair the software and do the same operations again and it didnt work.
Then I tried to uninstall 10.2.2 and reinstall it again. This time I got the following error. I havent seen this error before.
Any thoughts about this issue?
Thanks!!!
LSAAssociates
Worked for me. Just had to do the regedit fix only. This occurred when I tried to install CorelDraw X8 on my computer.
GabrielYarlequé
Forgot about this thread....I updated to the latest version and the issue got solved...
LisaHolm1
I updated to the latest version too. Problem not solved. Doesn't happen when I export a single page - happens when I export any range of pages from most mxds with data driven pages active. It will crash on export, I'll restart, it will let me export once (however many pages), then crash. I restart, it let's me export one more set of pages, crashes, then I must restart in the loop from hell. Infuriating waste of time. ESRI - are you fixing this?????????????????????????????
curtvprice
Open an incident with Esri tech support. The squeaky wheel gets the grease!
MargaretMaher
So far we have not been able to reproduce this error in-house.  As with other errors plaguing the Esri user community, the Esri developers are unable to fix the problem without a repro case.  I have noticed that this error also occurs in other programs like Adobe, Hallmark 2011, and several others that I am not familiar with.  In one post, there was mention of using 3D symbols in the map document, and that the error was resolved with the 3D symbols were removed.  This looks like it may be graphics-related, so upgrading or changing out the video card driver might allow progress with this issue.  FYI - the most recent report of this error message is occurring at 10.3.1 of ArcGIS Desktop.  Please keep us in the loop and post if you find any step that resolves this issue on your computers.  Margaret Maher
ahmedsaleh2
this message keep appearing after i close arc map and i cannot add data
ScottLehr
I am having the same Problem, Has anyone figured out a solution to this problem?
JonathanFrodge
Hi Scott,
I’ve upgraded to 10.4 and no longer get the error. If memory serves, I was receiving the error when attempting large map exports using data driven pages (i.e. to create a multi-page pdf ‘map book’). I had the following work arounds:
1) I would never attempt to overwrite a pdf, but rather delete the pdf and then re-export
2) I would occasionally have to close the mxd and re-open it if I’d used DD pages to navigate within the mxd, before it would export correctly.
Good luck,
-Jon
Jonathan Frodge / GIS Analyst – Assistant Project Manager
Civil & Environmental Consultants, Inc.
5899 Montclair Blvd. · Cincinnati, OH 45150
Toll-Free: (800) 759-5614 · Fax: (513) 985-0228 · Mobile: (513) 646-6582
http://www.cecinc.com<http://www.cecinc.com/>
Senior Leadership · Integrated Services · Personal Business Relationships
ValerieHanson
I have ESRI 10.4.1 and this is happening to me when simply exporting a large topo map to a pdf.  With another similar map it appeared to export, but there is no map.pdf where I exported it to.  I get the same error as Ahmed above.  I did close and reopen the mxd's to try again.  I most often get maps out to troops and those that request them in a very timely manner.  This is quite frustrating.
Robert_LeClair
Esri Esteemed Contributor
I found something via Esri Support Services that may be the issue:
BUG-000102530 : ArcMap hangs when printing to PDF if features have been labeled with extended Unicode letters
What font are you using?
