ArcGIS Desktop 10.3.1 on Windows 10 / VMWare Fusion 8.0.2
3272
11-19-2015 10:39 AM
WillMcClintock
Is there anyone who is able to successfully use ArcGIS 10.3.1 on Windows 10 running inside VMWare Fusion 8.0.2? Some things appear to work fine but when I try to reproject data, ArcGIS Desktop crashes. The procedure I'm using in ArcToolbox is one that I've run hundreds of times in ArcGIS 10.3.1 within VMWare Fusion 7 / Windows 7 with an otherwise identical setup.
Any special configurations I should be aware of in Windows 10 / VMWare that would create stability?
Cheers,
Will
