10.5.1 Spatial Analyst Issue: Close WindowERROR updateParameters Syntax Error
6703
7
10-13-2017 06:53 PM
HelenPlattner
I am trying to use the exploratory regression tool in 10.5.1 Education edition and am getting this error message:
"Close WindowERROR  updateParameters Syntax Error: Runtime error Traceback (most recent call last): File "e:\desktop10.5\ArcToolbox\Toolboxes\Spatial Statistics Tools.tbx#ExploratoryRegression_stats.UpdateParameters.py", line 2, in File "e:\desktop10.5\ArcToolbox\Scripts\SSUtilities.py", line 26, in import WeightsUtilities as WU File "e:\desktop10.5\ArcToolbox\Scripts\WeightsUtilities.py", line 22, in import SSPanelObject as SSPO File "e:\desktop10.5\ArcToolbox\Scripts\SSPanelObject.py", line 18, in import pandas as PANDAS File "E:\ArcGIS10.5\lib\site-packages\pandas\__init__.py", line 22, in from pandas.compat.numpy import * File "E:\ArcGIS10.5\lib\site-packages\pandas\compat\__init__.py", line 36, in from unicodedata import east_asian_width ImportError: DLL load failed: %1 is not a valid Win32 application.  Click for more detailed information."
I saw something about adding a path file which appeared to be a fix in an earlier version, but don't know where to find the necessary file or where to insert the command.  I've already tried doing a repair, then renaming the toolbox file and another repair, and have background processing turned off.  It is all the Spatial Analyst tools at issue, Getis-Ord General G gives this similar error:
"Traceback (most recent call last):   File "e:\desktop10.5\ArcToolbox\Scripts\GeneralG.py", line 15, in <module>     import SSUtilities as UTILS   File "e:\desktop10.5\ArcToolbox\Scripts\SSUtilities.py", line 26, in <module>     import WeightsUtilities as WU   File "e:\desktop10.5\ArcToolbox\Scripts\WeightsUtilities.py", line 22, in <module>     import SSPanelObject as SSPO   File "e:\desktop10.5\ArcToolbox\Scripts\SSPanelObject.py", line 18, in <module>     import pandas as PANDAS   File "E:\ArcGIS10.5\lib\site-packages\pandas\__init__.py", line 22, in <module>     from pandas.compat.numpy import *   File "E:\ArcGIS10.5\lib\site-packages\pandas\compat\__init__.py", line 36, in <module>     from unicodedata import east_asian_width ImportError: DLL load failed: %1 is not a valid Win32 application."
Any ideas?
HelenPlattner
OK, so I fixed it.  All it took was uninstalling Anaconda.
I clicked on some other posts relating to spatial stats and found that Anaconda seemed to not be playing nice. I first  tried getting them to work together as the post suggested, but I couldn't get it fixed and am out of time.  ESRI - this is a known problem through several releases, PLEASE FIX so we don't abandon you to another product because it took too long to find the problem or can't just uninstall.
DanPatterson_Retired
Your installation path is a bit unusual...
conventional install with no direction would indicate a path to the toolboxes like this
C:\Program Files (x86)\ArcGIS\Desktop10.5\ArcToolbox\Toolboxes
HelenPlattner
Yes, I understand. However, I run all my programs from my E drive and is not a problem for any of the other toolboxes [outside of Spatial Analyst] in this version, nor has it been a problem with previous versions of ArcGIS Desktop that have been on my machine.
HelenPlattner
Here are additional similar instances of this happening on machines with the more usual pathway:
Error while running Hot Spot Analysis (Getis-Ord Gi) tool in ArcGIS 10.4.1 - Stack Overflow - No Answer
Error message(s) when running Spatial Statistics tools - This one has a solution if someone could help me understand how to do this:
[add] "C:\Python27\ArcGIS10.1\Lib\site-packages\" to the PYTHONPATH environmental variable
locate this folder and file
C:\Python27\ArcGIS10.5\Lib\site-packages\Desktop10.5.pth
and examine its contents in a text editor and read this... help file topic
 10.3 is substituted for 10.5
All this other copy this and that stuff... don't like that, but if you can't use a standard install, try what you have to
HelenPlattner
OK, I found my file:  E:\ArcGIS10.5\Lib\site-packages\Desktop10.5.pth and opened it to see:
E:\Desktop10.5\bin
E:\Desktop10.5\ArcPy
E:\Desktop10.5\ArcToolBox\Scripts
Exactly as the example said it should be. I double checked and the files are located in their respective locations - check.
However, then I went in and looked at the actual code for the Exploratory Regression tool... then I went in to a tool I know is working (Iso Cluster Unsupervised Classification) and I viewed the code.
I thought I might have stumbled upon the problem from my poking around when I realized that C++ is CASE SENSITIVE maybe the problem lay in the code as such:
IsoClusterUnsupervised.py is written all lowercase but without an import statement.
Whereas the Exploratory Regression code says: import arcpy as ARCPY
Now my file says E:\Desktop10.5\ArcPy so everything should be good right?  Nope.
The ACTUAL file location is E:\Desktop10.5\arcpy
So I changed the pth file to reflect this change, I didn't think it would work - it is giving me line numbers for the errors right? so it must be making it to the files...  I was right and it didn't work (always hopeful for the simple fix) but wanted to try SOMETHING.
Then I read this article Enable Python installations that were not installed by ArcGIS to access Arcpy functionality | Python...  so ok, go to the system file and add the path there... still no good.  I don't have another code to delete it all (including the past remnants that did not get removed when I did the uninstall of the prior version) and start again.
Any other ideas please    I have to get my project done and at this point I may have to abandon Arc to do the analysis that I will then have to bring back into Arc - not ideal!
HelenPlattner
AlexanderDunkel1
Thanks for the answers. For me the source was python_27_64 bit installed next to 32bit version arcgis is using. This is a mess, why does ESRI not install it into ArcGIS directory without any paths?
