I'll start off saying I'm not sure how big of an issue it is to create a spatial view and not have a unique identifier, but it seems like something that might cause issues down the road so I want to avoid it.
Ok I figured this out!
(EDIT -- NEVER MIND!! The query layer (as illustrated below) works in ArcMap, however, you can't publish a "complex" query layer (e.g. one that has joins or a where clause). You CAN publish a "simple" query layer (no joins, no where clause). But in my case I needed those joins and where clauses and I need to publish it so this doesn't help. Back to spatial views with no unique identifier!)
Instead I created a Query Layer in ArcMap. I'm using 10.3.1, and followed these steps:
1. In ArcMap, Click File > Add Data > Add Query Layer.
2. It will ask you to provide the database connection. (see image below)
3. Type in a name for your new layer.
4. Create a query. I used the same SQL that I would have used to create the spatial view (which I copied from SQL server management studio).
This gives you a new layer in your MXD that does exactly what your spatial view would have done, plus it adds an "ESRI_OID" field that has a true unique identifier.
You can save and publish the MXD as usual. You can even save the layer as a .lyr file to easily use in other documents.
So the downside is that you don't have a spatial view in your geodatabase to easily use, but since you can save .lyr files you don't have to rewrite the SQL every time you use the same data -- or even similar data, as you can edit the query in ArcMap whenever you need!
