Please let me know how to check if any feature has a longitude value that is less than –180.00000 or greater than +180.00000
No one here to have a look into this.
Hello,
We apologize for the late response. Is it a line feature? If you so you can use the Evaluate Polyline Length to check if the feature is within the specified range. Is this your business scenario?
Evaluating segment, part/path, and polyline lengths—Help | ArcGIS Desktop
Hello,
We want to perform a check for polylines, polygons and points, if any feature lat/long values not between -180, -90 and 180,90 it should be an error. In the suggested configuration between function not allowing negative values. Please suggest how to configure this check.
You could use a python script to get the X,Y coordinates of polylines, polygons and points and then identify negative values. https://pro.arcgis.com/en/pro-app/arcpy/get-started/reading-geometries.htm
Thank you for sharing a link. Can you please explain how to use this script in Data Reviewer ?
My development environment is .Net so please suggest on this.
