Simple vs Non Simple
16778
13
10-21-2010 02:00 PM
BartHound
When is a Parcel polygon a Non Simple Geometry?  I recently ran the invalid Check for our parcel layer and it came up with 2 problem polygons that were listed as non simple polygons.  Not sure why that would be the case, though.
MichelleJohnson
Have you checked out the Repair Geometry GP tool?
AnastasiyaGrecu
Hello Michelle,
Do you know if there is a way to repair geometry and address "bad geometry"  issues in SDE environment?
Anastasiya
MichaelVolz
Esteemed Contributor
Can you identify the bad geometry?  Then select just those features and export out to a file gdb and see if you can repair it there and see what it does to your geometry.  Then you might be able to load the repaired features back into SDE after you deleted the bad geometric features.
MichelleJohnson
Hello.
Unfortunately, the Repair Geometry geoprocessing tool does not work on enterprise geodatabases.
But if you look at what that tool does, you could probably find other tools to do what it's doing.  For example, some of the more common geometry issues that I come across are NULL geometries.  You can use Select By Attribute to select where the Shape_Area or Shape_Length is NULL or 0 and then Delete those features.
Another is polylines with duplicate vertices.  You can use Generalize or Simplify Line to remove excess vertices.
Good Luck!
michellej.
