ReviewerConsole.exe run on selected features
2839
08-07-2012 12:14 PM
RyanStephany
Is it possible to use ReviewerConsole.exe on just selected features?
My /pd: is a sde connection file.
I see there is a /type: option with Attribute, Spatial, Reviewer.  I'm not sure if I want to use this though, because I don't want to use a product library.  Are there any examples with /type:.  I can't find any.
Is there another way?
I have also tried to select the features I want to run against from my sde connection file.
Ryan
MichelleJohnson
The ReviewerConsole.exe will run on Full Database (this is the default) or Changed Features Only (on a versioned gdb) using /changedonly.
With the new Create Reviewer Session and Execute Reviewer Batch Job GP tools at 10.1, you can create a python script and then schedule it to execute using Window's Task Scheduler.  The Execute Reviewer Batch Job GP tool allows you to pass thru an Analysis Area to restrict the validation on a given extent.
