Reviewer Session Manager Reviewer Methods
1978
10-25-2010 05:06 PM
TedCronin
If I select How to write results on the Reviewer Methods Tab, via the Data Reviewer Table Writer, if I then click Apply and Close, when I reopen the dialog, I expect to see the How to Write Results populated with the Data Reviewer Table Writer selection that I selected, Applied in the first step, but currently, every time I select open the Session Manager, and go to the Reviewer Methods Tab, the drop down is blank, as if I did not complete the first step the first time, or Apply did not work, either way, I would expect to set this value and have the value get retained in the properties somehow.
TedCronin
There is a similar behavior where I select the Advanced Button to bring up the additional Tabs, when I select Advanced and click Apply, I expect the second time, I open the manager to see the additional tabs already displayed in the dialog.  Currently, I need to reselect Advanced every time I open the Reviewer Manager dialog.  This requires more button clicks.
End Session remains pressed, shouldn't the Advanced Button remain pressed as well.
