Reviewer Overview Window Properties
1740
10-27-2010 03:50 PM
TedCronin
When Choosing a Reference layer, and setting the active grid feature layer and field to label, then saving the document, or MXD, the values selected are not being saved with the MXD, so I need to reset them each time.  I would expect that if I set the properties for my Reviewer Overview, that when I save the MXD, the properties that were saved would remain saved after I reopen the mxd at a later time.  These properties should not have to be reset each time the Map doc is opened.  Is the expected behavior for this properties window, to not retain the values chosen in a previous session?
