Hello All,
1488
11-02-2016 07:19 AM
KelleyAllen
 I am getting an error that reads "Warning! There was an exception loading the batch job(s). Loading aborted" We cannot seem to use the checks besides on the PC they were created. Using desktop 10.2.2
PaulDavidson1
Sounds like you might have some pathing issues?
Look at how the data the batch runs against is defined on the PC where it runs.
Then make sure the other PCs have similar setups.
Is this against an EGDB?
Do your various users have proper permissions for data & folder access ?
I don't know if the location of the batch job file matters, but that might be an issue.
Sounds like a good thing to report to support and have them work with you to verify things.
Worst case, rebuild the job on the other PC and see if it doesn't run.
Depending on how complex it is, this could be your easiest solution.
If you have problems with that, maybe build it in stages if it is doing multiple checks.
MichelleJohnson
This is an obvious question, but thought I would ask anyway.  Are all computers using ArcGIS 10.2.2?  Sounds like maybe you were opening a 10.2.2 on a 10.1 machine??
