Hash Pattern in Reviewer Window Changes
2113
10-27-2010 04:13 PM
TedCronin
If I select Grid Cells in the Reviewer Window using the Select Grid Cells Button, then Select the Zoom to Selected, my Hash pattern envelops the Selection which is what I would expect, if I however, adjust the Map View by using the Continuous Zoom Pan Button (Any button on the Standard Toolbar should suffice) by just a very small increment, the Hash Pattern Grows beyond the Selection inside of the Reviewer Overview Window.  This is not What I would expect.  The Hash pattern now reflects the view in the Map, not the Selection in the Overview Window.  Is this the expected behavior?
Occasionally, you can see the same behavior with the Hash Symbol when Zooming to Active Grid Extent from the Right Context Menu.  This example is harder to repro.
KumarBhardwaj
This is expected behavior which you mentioned regarding the Hash Pattern Grows beyond the Selection inside of the Reviewer Overview Window when Continuous Zoom Pan Button is used.
We cannot constrain the main ArcMap viewer based on the grid cell selection in the Reviewer Overview Window. If you want the same view (based on the grid cell selection) again in the main map you can use the 'Zoom to Selected' option in Reviewer Overview Window.
TedCronin
I think I may need to create a video on this issue, I am only using the main map to trigger the weird behavior in the Overview window.  The issue is still the overview window, and how the hash is rendered.  There is an inconsistency in the hash.  A video will clear this up, a lot.
TedCronin
Here is the video:
http://www.youtube.com/watch?v=sb7TbxjRReU
