Explode Deleting Features with Multi Part Checks
2053
10-25-2010 04:14 PM
TedCronin
When working with the multi part Line and multi part polygon Checks, if i select explode to break apart the multi part geometries, the first time, it actually deletes the selection, then I undo, and re run explode, then the geometries are exploded as expected.  I am seeing this fairly consistent, the first I run these checks after creating a new session.  So, for instance, I choose the single check parcel lines, the first time I select explode, the parcel lines, are deleted, then undo, then explode the second time, and I am good to go.  If I then move to another feature via Browse, I am successful the first time for each subsequent explode where nothing is deleted.  However, if I then run the multi part polygon tool, on say Parcels, the first time, the parcels are deleted, then I undo, then re run explode, and the geometries are correctly exploded.  Each subsequent explode is then run successfully.  Does this make sense?
If you need me to put up a video on Youtube, let me know.
KumarBhardwaj
Thanks for letting us know this issue, following bug has been logged for the same:
Bug: 3290
Title: Running Multipart Polygon Check and Browse Features and Explode Multi-part Feature deletes the feature
TedCronin
Thank you Kumar for getting back to me, and logging the issue.  Not huge, but definitely good to know for training purposes.
