Edit Features
1956
12-26-2011 07:26 AM
DanaYeori
Can I edit and correct features (By selecting the records in the map or on the Reviewer Table), that was found with error with in the Data Reviewer, and track the status change in the Reviewer Table?
thanks
Danay:confused:
DanHopkins
The Reviewer table is a window that displays the records or results that have been found using Reviewer checks and visual review and allows you to work with the records and configure the table. Using the Reviewer table, you can zoom to individual features that have been recorded in the Reviewer table. The Reviewer table contains the features and database records that are returned by the checks that are run in the form of a batch job or individually. The features that fall within the thresholds defined in the checks are recorded in the Reviewer table so they can be corrected and evaluated as needed.
For more information regarding the Reviewer Table, please see the following web-help topics:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//01020000003p000000
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/A_quick_tour_of_Data_Reviewer/01020000...
In the web-help topics listed above, please refer to the sections on the Reviewer Table.
Regarding "track the status change in the Reviewer Table", are you referring to the Correction Status and the Verification Status talked about in the following web-help topic:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//010200000057000000
If yes, please refer to the following web-help topics for more information regarding Updating the Correction Status and Verification Status for records in the Reviewer Table:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//0102000000m8000000
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//010200000088000000
