DR: Using a newer version but running the batches against an older version of ArcGIS
3903
08-18-2015 07:25 AM
JonahWaterman
Is it possible to write the results of the reviewer tables to a newer version of ArcGIS( Ex. 10.3) however run the batch files against version 10.1? Thanks
MichelleJohnson
Yes, you can validate a 10.1 geodatabase and have a 10.3 Reviewer workspace.  Obviously, these have to be separate geodatabases.  And you have to be using ArcGIS 10.3 Desktop on the client machine.
JenniferMcCall4
Do you mean that you want to run data reviewer against data in a 10.1 geodatabase, but write the results to a geodatabase created in 10.3?
MichelleJohnson
JonahWaterman
Thanks Michelle!!! Just a side note I talk with our GIS Administrators the other day and they want to roll full force with DR for Server and incorporate the dashboard through Flex/ Java script. Very exciting times over here in NC. Thanks for everything!
